5 members (Bill Hanlon, 68ironhead, 48jim1ton, Hotrod Lincoln, Otto Skorzeny), 121 guests, and 2 robots.
Topics128,032
Posts1,055,517
Members48,425
#1418132 07/25/2021 9:11 PM
Crusing in the Passing Lane
Installed Delphi(ex Saginaw) power steering in my ‘55.
Ed
EdPruss #1500246 05/09/2023 9:12 PM
Do you have a part number on that? More pics of the hoses and pitman arm?
1956 Chevy School Bus Superior Body
EdPruss #1500264 05/10/2023 12:03 AM
Here you go. I will look for casting number on box, tomorrow. Two sets of casting numbers: 4J29. 26078703 WFI, last 3 letters are suspect. Delphi numbers. Might be just as easy to search for same or similar configuration boxes with vertical output shaft next to 4 mounting bolts. Worm gear on outside. Input shaft aft.
I had to shorten my drag link, got a left hand tap made for the cut off end.
Pitman arm can be mounted any way you need, if skip splines are off, just file a new spline in the middle of the skips with a 3 cornered file.
4 mounting bolts usually are too wide to be able to mount directly to frame without a wider mounting bracket(visible in pictures), make sure to sleeve the mounting bolts where they go through the frame, unbushed mounting bolts have been known to crack frames.
Input fittings have corks in them if not visible in pictures.
Need to get new hydraulic lines made up.
Good luck.
Ed
EdPruss #1516803 09/11/2023 12:59 AM
Moderated
Moderated
Nice I’ll be do this very awesome conversion. Just picked up a 1991 P30 motor home for the disc brake axles!,
