2 members (Nick in Manitou, klhansen), 77 guests, and 3 robots.
Topics128,080
Posts1,056,315
Members48,442
#1516553 09/09/2023 11:23 AM
Moderated
Moderated
hi gang from Canada
got a few big bolts from the 70s and early 80s in the yard here just for yard use as they go cheap and dont want to see them scrapped. 350, 365 and 427 engines. my kids love to play in them and they all run well.
but I located my dream big bolt... sierra, 79, with a factory 4-53T which seem to be more common in the US but the only 1 I have seen forsale in Canada. its getting delivered tomorrow. going to impress my neighbors with that noise! plan to get it on the road, shorten wheel base and put a dually box on her. i have done that once already with a gasser.
anyways the previous owner could not source drums for the life of him. no online catalogue lists the actual drums, just hardware and pads. they are 10 bolt 15x5 from the build sheet. GM H150 axle. i see big truck parts for drums in that size but how do I know they will fit?
wisdom appreciated.
The most common difference is the diameter of the lug bolts, and the bolt circle. Make a few more posts so you have access to the private message function on the forum ( I think it requires 4 or 5 posts to get past "moderation") and contact forum member Ed Pruss. I believe he has a method of re-drilling the bolt holes to the proper diameter and spacing to make later model wheels fit- - - -it might be possible to do the same thing with brake drums.
3B Offline
Hy rusty krusty, if you could give us the trucks model number and or serial number we may be able to get an o.e.m. part number and see if anyone has a cross to it. Are your wheels Budd (inner and outer nut system), or Motor wheels (single nut per stud)?
Moderated
Moderated
sure its a 79 gmc 6000.
i found the parts book online page by page in a jpg. anyone have a pdf? i can only click next so fast 😂
Moderated
Moderated
I found a webb drum catalogue that lists 2 possible fits. same surface dimansions, bolt pattern and spacing. lug size is an easy fix if needed and would have to confirm existing dimensions. fingers crossed!
Crusing in the Passing Lane
Pictures always help when one has enough posts!
Ed
