1 members (NJC), 86 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1516458 09/08/2023 3:25 PM
working on 53 Chevy, family truck- just sifting through bucket of parts after engine rebuild...thanks
Family truck 1953 1/2 ton w/216
weewilly #1516472 09/08/2023 4:52 PM
weewilly,
I'm going to say "throttle linkage pivot bolt".
See screenshot sample pic below.
Dan
Throttle linkage pivot bolt
~ Dan
1951 Chevy 3 window 3100
weewilly #1516476 09/08/2023 5:00 PM
I think Dan is spot on.
It’s showing a wear groove near the outer end where the throttle crank rides. You might consider welding that and resurfacing.
weewilly #1516500 09/08/2023 8:12 PM
GMC calls it an "Accelerator control lever stud", part number is 838420. It was used on Chevy cars and trucks from the 30s into at least the 50s. GMC used it from 39 to at least 1960. Part number is 838420.
Chevs of the 40s has them listed under the same part number.
Your looks a lot better than mine did.
weewilly #1516501 09/08/2023 8:16 PM
That one is a lot different than the one weewilly posted.
I guess the lever is held in place with jam nuts instead of an E clip.
1950 Chevrolet 3100 (Ol' Roy)
weewilly #1516533 09/09/2023 12:42 AM
A cool trick for the throttle crank which goes on that stud is to find a thin-walled piece of pipe which fits on that stud, and drill the holes in the throttle crank for the pipe to fit in and weld the ends of the pipe ot the throttle bracket holes.
This gives you a much larger bearing surface for the throttle bracket to ride on the stud, resulting in smoother operation, as well as not having to worry about the grooves that are currently in that stud. Should last for 3,000,000 miles.
weewilly #1516548 09/09/2023 5:01 AM
H Online: Content
The KISS principle applies here- - - -a plain old hex bolt and a jam nut will solve the problem of the worn stud, and there are a few hundred of them available at the corner hardware store.
weewilly #1516739 09/10/2023 2:49 PM
62401
I'm thinking forget the throttle linkage doohicky ... That's the first time I've ever seen the turn indicator mounted there. Probably a very effective and noticeable place ...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John Milliman #1521060 10/09/2023 2:39 AM
Riding in the Passing Lane
It took me awhile to get that
George
1972 Chevy c10 Cheyenne Super
Moderated by  klhansen, Rusty Rod
