Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Hush), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
I have two engines I'm not sure what they are the first Id nu is F0719J ( i think it is a 216 but that is all I can figure out) and the other is KAA402952 ( I'm thinking it was made April 2, 52 ) but that's it. Any help?
Last edited by Gdads51; 09/07/2023 11:15 PM. Reason: moved and edited to become its own thread
Still At It
48 Thriftmaster
64 Impala
62 Impala
Half the fun is making the mess!!!!!The other half is figuring out now what do I do?????
Still At It,
Here is what I could find in searching the GM Heritage Site Info Kits:
F0719J decodes as:
F = Flint plant 1957 Truck 235
07 = July
19 = 19th day of July
J = Installed originally in a 3400-3500-3700 Series truck (regular production)
KAA402952 decodes as:
K = 1952 216
A = Passenger car
A = Flint plant
402952 = assigned sequential serial number (factory numbers started with "1001")
In both cases, it would help if you could provide the block casting numbers for each engine as well as the casting date codes as those will help confirm what you have.
Dan
~ Dan
1951 Chevy 3 window 3100
Just to add to Dan's info, the F0719J engine could be found in a 1957 (3400-3500-3700 Series truck) or a 1958 through 1962 (31, 32, 36 or 38 Series truck). So, having the casting Date Code will help narrow down the year if that's important.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
