1 members (GMCJammer51),
92
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 34 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 34 | I have two engines I'm not sure what they are the first Id nu is F0719J ( i think it is a 216 but that is all I can figure out) and the other is KAA402952 ( I'm thinking it was made April 2, 52 ) but that's it. Any help?
Last edited by Gdads51; 09/07/2023 11:15 PM. Reason: moved and edited to become its own thread
Still At It
48 Thriftmaster 64 Impala 62 Impala
Half the fun is making the mess!!!!!The other half is figuring out now what do I do?????
| | | | | Joined: Sep 2009 Posts: 6,215 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,215 | Still At It, Here is what I could find in searching the GM Heritage Site Info Kits: F0719J decodes as: F = Flint plant 1957 Truck 235 07 = July 19 = 19th day of July J = Installed originally in a 3400-3500-3700 Series truck (regular production) KAA402952 decodes as: K = 1952 216 A = Passenger car A = Flint plant 402952 = assigned sequential serial number (factory numbers started with "1001") In both cases, it would help if you could provide the block casting numbers for each engine as well as the casting date codes as those will help confirm what you have. Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | Just to add to Dan's info, the F0719J engine could be found in a 1957 (3400-3500-3700 Series truck) or a 1958 through 1962 (31, 32, 36 or 38 Series truck). So, having the casting Date Code will help narrow down the year if that's important. Mike B  | | |
