| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | If I have fish eye in places what is the corrective method? It looks like the epoxy did fill in. I have scuffed all my panels and blended in the high build over the bad reaction areas. I think I am ready to try and shoot this stuff again as long as other think I can shoot over areas that originally fish eyed on me. | | | | | Joined: May 2015 Posts: 11,008 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,008 | I think you just have to sand them out and re-shoot. I'm going that route on one that I have on the cowl of the cab I just painted. I'm thinking of a soap and water washdown AND wax and grease remover before I re-shoot it. I sanded down just into the primer layer, but left some on.
Maybe someone else with more experience with fisheyes will weigh in.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | It could be something in or on the primer that caused the fisheye. I have always sanded to bare metal, cleaned with wax and grease remover, primed, filled with spot putty if necessary, primed, sanded than shot the color again. Anytime I tried a shortcut, the fisheyes reappeared, then I just doubled the work.
Maybe there are others that have had success with other methods.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | One real important thing to remember, if it is actually fish eye due to contaminants, you want to clean the surface with wax and grease remover/laquer thinner/etc. before you start sanding. If the contaminants are oil/silicone the sanding will imbed them into the paint further.
| | | | | Joined: May 2015 Posts: 11,008 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,008 | I fixed my fisheye today. Washed it with dish detergent and water, rinsed and dried, then used wax and grease remover. It's gone now. Cleaning prior to sanding is a good idea. I dodged that bullet.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I fixed my fisheye today. Washed it with dish detergent and water, rinsed and dried, then used wax and grease remover. It's gone now. Cleaning prior to sanding is a good idea. I dodged that bullet. Are you saying it went away just from washing? Or you washed it, sanded it, and resprayed it? | | | | | Joined: Oct 2021 Posts: 6,704 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,704 | Ya, that's what I was wondering.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,008 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,008 | I sanded down into but not through the primer, washed with detergent, wiped down with wax and grease remover and resprayed that spot. It would have been a lot less work if just washing it with detergent made it disappear, but unfortunately, it doesn't work that way.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,704 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,704 | I first thought you were able to wash it and then sand it out.
| | | | | Joined: May 2015 Posts: 11,008 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,008 | I first thought you were able to wash it and then sand it out. The paint was thin enough at the bottom of it that the primer was showing. So that wouldn't have worked.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | It looks like the bottom of the eye filled in with material. I have it sanded close to the bottom of it. Can I hope it self levels (As advertised) in, or not? | | | | | Joined: May 2015 Posts: 11,008 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,008 | I sanded till it was level, and like i said into the primer layer. If there's still a depression, and you have it clean, and can get paint into the bottom of the eye, it should self level. You may need multiple coats to get it completely flat. Maybe sanding between coats. Mine was on a basically flat surface and I shot about 3 coats before each coat was completely dry. It's the best looking spot on the cab.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Not something you might want to do, but something I observed back in the early '70s. A friend with a wrecking yard was fixing up a vehicle, which I don't remember anything about. It may have been a vehicle for the yard, I don't recall. He had invited a friend, an old painter to come by to shoot the paint. He shot little more than a panel when he recognized the fisheyes. He took the cup off, sprayed WD-40 into it and kept painting. Sprayed WD-40 into the rest of the paint. and the finished vehicle looked just fine. The paint was plain automotive enamel that dried very slowly. The oil in the paint was compatible with the contaminants on the body and the paint flowed out as it should. I have no recollection of how well or long it survived.
Maybe not something you'd try on your nice truck, but a mower or something .
'67 GMC 3/4 292 4spd
| | | | | Joined: May 2015 Posts: 11,008 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,008 | I think something like that is used for paint that has a hammered look. Might be something to try on a Stovebolt heater to get that effect. I think back in the 70's, WD-40 still had silicone in it. Normally that's death to a good paint job.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2012 Posts: 44 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 44 | Early 60's 3M came out with a fish eye elimnator called Smoothie, don't know if its still around
There is not a tool made that if you don't try hard enough you can't break! 1952 3100 261 T5 3.08 Gov Locker
| | | | | Joined: May 2015 Posts: 11,008 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,008 | Still available. Smoothie
