3 members (klhansen, 3800GUY, 1 invisible), 63 guests, and 3 robots.
Topics128,153
Posts1,056,847
Members48,456
#1515897 09/04/2023 9:48 PM
Ok, let me start by saying I am an idiot. Now that’s out of the way….can I put my early 235 w/ factory 3spd transmission back together WITHOUT 2 of the dowel pins in the crank / flyweel?
The reason I’m asking, I attempted to install my flywheel. Laying under the the truck, I could see the bottom dowel pin and the center hub were aligned, so I started the flywheel bolts and systematically tightened a little at a time, pulling my flywheel up flush. It was a tight pull all the way, which should have shown I had a problem. When I got it all together and started to torque the bolts, I noticed that two of the dowels were not sticking through the flywheel. Come to find out, I had the pins / holes out of alignment and ultimately pressed the other 2 dowel pins back through the crank. Everything seems to be turning free, but 2 of the dowel pins are protruding inward instead of outward. My question again, will it be OK to run it this way, without 2 of the dowel pins sticking through the flyweel holes? Again….I AM AN IDIOT.
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Danny,
See the screenshot below taken from one of the Chevrolet Master Parts Catalogs that give a cut-away view of the engine with flywheel and associated parts installed.
If you zoom in you can see that the alignment pins for the flywheel to crankshaft (shows pin at top and bolt at bottom) don't seem to have a lot of room when pushed into the crankshaft holes. Those holes go all the way through the crankshaft and if the pin is pushed in far enough, could contact the rear main bearing block casting and/or cap and may cause damage when you turn-over/run the engine.
Have you tried to spin you engine over by hand to see if there is any interference???
From what I see in this picture, I think the only way to resolve that is to remove the oil pan and see if you can pry the pins back outward on the crankshaft. Of course you will have to remove the flywheel to allow them to move back outward in the crankshaft.
Jerry (Hot Rod Lincoln) will know the answer to your question with eyes closed. Hoping he will chime in with some words of wisdom as mine isn't from hands on experience.
Dan
235 cut away view of crankshaft and flywheel area with alignment pins.png (207.21 KB, 140 downloads)
235 engine cut-away view of rear main and flywheel mounting
~ Dan
1951 Chevy 3 window 3100
Originally Posted by Gdads51
Danny,
Dan
Thanks, Dan,
Yes, I removed all the spark plugs and the engine turns very easily by hand. The inverted dowels don’t seem to be making contact anywhere, I’m just not sure if it is OK to finish the install and leave it like this. I don’t know if the dowel pins serve any other purpose other than alignment or if it could throw off the balance in any way.
Danny
Insomniac
Insomniac
You are not the first one to make this mistake. Some time ago, somebody else confessed to doing this. Unfortunately, I can't find the thread where the solution was posted.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks Gord&Fran. I guess it’s comforting to know I’m not the only idiot that’s done this, LOL. But it sure ruined my day.
3B Offline
Hy Dltalfa, I would do whatever I had to do to pull the dowel pins back into position and install the flywheel correctly, without the flywheel correctly installed your timing marks will not be viewable in the bellhousing window.
Thanks 3B. But to drive the dowel back out would require removing the oil pan, dropping the rear main bearing cap and then hopefully being able to drive it out. Then I’ll need a near rear seal and new pan gaskets. I’d hate to do all that if it’ll perform OK as is. Now realizing my error, I can align the flywheel correctly. Just wondered if the inset dowels would cause any problems.
O Online: Content
Send Hot Rod Lincoln a PM for the definitive answer.
1950 Chevrolet 3100 (Ol' Roy)
One pin may not be enough to keep the flywheel centered. The bolts typically have a little bit of space between them and the hole, so the flywheel could slop a little bit if there weren't 2 or more close fitting pins correctly installed.
Riding in the Passing Lane
Can you look in & see the ends of the dowels? How much clearance do you have between the dowels & the oil pan? If it is not too close anything you will be OK. They may hit the flywheel cover when it is installed. You might check that. You can trim the cover a little if necessary. It won't effect the balance as it is close to the center of the crank.
George
1972 Chevy c10 Cheyenne Super
George
I can’t see the portion that is driven inside, but it’s not anywhere near interfering with the oil pan. The oil pan is “u-shaped” around the crank where the flywheel bolts. The engine rotates fine with no interference anywhere….with the oil pan installed. Thanks for the input!!
I've been out of town on a big road trip- - - - -deep south Florida and back- - - -got a PM exchange going with the OP. I believe he will be OK, as long as he picks out the right hole in the flywheel to engage the remaining dowel. Otherwise, he's going to need to set the timing with either the #2 or #3 cylinder, not #1!
