7 members (klhansen, edgardo, Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, 1 invisible), 57 guests, and 2 robots.
Topics128,059
Posts1,055,820
#1515636 09/02/2023 11:56 PM
I got the clutch and pressure plate out today. Measured it at 10”.
See pic. Can’t find it anywhere
Need some help figuring it out.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1515641 09/03/2023 12:31 AM
I think any disc from 10" thru 11" would work, the 11" was the HD clutch used in your truck. Seems like the modern replacement size is 10-3/8".
Contact Fort Wayne Clutch to see if the have what you need or if they can re-face your existing?
https://fortwayneclutch.com/
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
T-Doug #1515662 09/03/2023 2:20 AM
Insomniac
Insomniac
I bought a 10" clutch kit from Rock Auto about this time last year. Unfortunately, I needed a 9 1/8" kit. Make sure that the kit you buy matches your flywheel.
https://chev235guy.blogspot.com/2020/06/216-235-261-flywheel-pressure-plate-and.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
T-Doug #1515698 09/03/2023 11:22 AM
The measuring tape is not accurate that way.
That is less than 10 inches
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Guitplayer #1515702 09/03/2023 12:38 PM
Replaced my clutch &pressure plate last year ======went to local FLAP and had parts in a day.
T-Doug #1515704 09/03/2023 1:57 PM
II purchase a kit form the local O-Riellys , PTQ K1874-06 for my 1954 3600. Works perfectly. Its a 10" clutch plate , 10 spline. Kit cost $139 currently and includes the clutch, pressure plate, throwout bearing, pilot bearing and that almost worthless alignment tool. My mechanic resurfaced the flywheel and the clutch works just fine.
Ron - - Dusty53
1954 Chevy 3604
T-Doug #1515894 09/04/2023 9:31 PM
Found a 10” clutch kit at O’Reily for $139 this morning. Looks exactly like what came out of the truck.
Doig
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1515926 09/05/2023 12:05 AM
ok.. pilot bearing didn't come out like its supposed to with the grease fitting.. question is if I'm pulling the flywheel can I wait until its out to remove it..
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1515967 09/05/2023 12:18 PM
Yes, the pilot buhing is in the cranksahft and not involved in the flywheel to crankshaft interface.
1949/50 3600 Project
Follow in Project Journals
