1 members (GMCJammer51),
92
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2018 Posts: 141 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 141 | So I discovered my pilot bushing in my 1954 235 is bad and since I’m in there anyway, i am doing a clutch job. My question is that the kit contains a replacement pilot bushing but I’ve had two people tell me to get a pilot bearing instead. Is this a real replacement or is it designed to just replace with a similar brass pilot bushing? | | | | | Joined: Feb 2001 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 41 | Bronze bearings work just fine. Just make sure when you drive it in, you use a stepped tool so you don’t roll the edges. Ball bearings work too, but they can be harder to line up. Also when they go bad, they go really bad. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Do not use a bearing type pilot. They eat up and destroy the tip of the input shaft and are never necessary for a street driven vehicle. Uses bronze bushing, preferably one made from oilite. Use an old input shaft to drive it in if you have one.
Mike
| | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | Do not use a bearing type pilot. They eat up and destroy the tip of the input shaft and are never necessary for a street driven vehicle. Uses bronze bushing, preferably one made from oilite. Use an old input shaft to drive it in if you have one. Well stated.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2018 Posts: 141 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 141 | Thanks. Went with a bronze bushing. Drove it with the peen end of a small ball peen hammer ( radius was perfect for the bushing end ) being driven with a larger ball peen hammer. Works like a champ. | | |
