7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami),
60
Mod | | | Forums66 Topics128,030 Posts1,055,421 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2023 Posts: 21 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 21 | Hello out there ! My 49’s engine is Blue, is there a name for that color so i can find matching spray . | | | | | Joined: Oct 2021 Posts: 6,698 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,698 | Your engine should be grey, not blue. https://oldchevytrucks.com/pt115.htmlPerhaps your engine came from a later model Chevy car whose engines were painted blue.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2010 Posts: 484 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 484 | Otto, You are correct, but I'm going a different path. My truck came with a 235 engine painted blue that likely came from a car. That engine was locked up, so I found a replacement 235, also from a car and painted blue. I decided to keep the engine blue as an homage to the history of both the truck and engine. It just works for me. I used duplicolor engine paint for those parts that needed paint. The color was DE 1609 Chevy Blue. It closely resembles the original blue paint, but nothing will exacty match 60-70 year old, baked on paint. I throw this out there as an alternative, because so many of the engines came out of cars. OBTW, duplicolor has several different shades of GM blue engine paint, so you have choices if blue is acceptable.  | | | | | Joined: Oct 2021 Posts: 6,698 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,698 |
| | | | | Joined: Aug 2023 Posts: 21 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 21 | | | |
