0 members (),
145
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2018 Posts: 141 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 141 | So, I’m replacing the clutch in my 1951 3100 that has a 1954 235. I pulled the clutch, pressure plate, and flywheel ( all need help). Pulled the pilot bushing out. It was tweaked so instead of a cylinder with a straight hole in the center, it was more of a parallelogram with an angered hole. Input shaft and end of crank weren’t damaged. ( was wondering where the vibration was when I drove it; rebuilt the whole rear end, had a new balanced driveshaft made, and still had vibration!). Got a clutch kit with all needed parts. My question is: Does the crank end have a bearing in addition to the brass/bronze pilot bushing? I notice a larger recessed circle around the pilot bushing hole. Also, noticed it has a 9 1/2”clutch , so does that mean the 54 engine came from a car? So many questions. | | | | | Joined: Sep 2009 Posts: 6,215 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,215 | Snowman51, The larger recessed hole in the crankshaft end you mentioned outside of the pilot bushing hole was meant to allow the "Powerglide" automatic transmissions toque converter to nestle up to the crank properly when the 235 was installed in passenger cars. The crank would originally have had the pilot bushing hole, without a bushing, and the secondary larger hole to allow for the "Powerglide" converter center stub to fit properly to the flex-plate and crankshaft. Only the one pilot bushing needed for the manual transmission input shaft to ride in for your application. If you aren't sure what 235 you have, take some pictures of the casting/date codes on the block and the stamped serial number pad behind the distributor and post them in a new thread in the Engine Shop. Folks will be along to help answer that question once you ask.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2018 Posts: 141 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 141 | Gdads51, Thanks for the info. Thought so but wanted the expert opinion. | | | | | Joined: Sep 2009 Posts: 6,215 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,215 | Snowman51, Can you post a picture of the old bushing??? Your description of the "angered" hole (angled maybe???) sounds like the bushing was incorrectly installed in the crank. That or maybe you have an issue with the transmission input shaft (bent, worn out bearing or something similar) which may account for your bad vibrations??? With so many questions, there can also be so many answers, just ask away.  Dan
| | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | The 9 1/8" clutch was standard on your truck.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2023 Posts: 103 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 103 | If you have an automatic crankshaft and are using it with a standard transmission be sure to order the correct size pilot bushing. Rock Auto lists two different sizes for a 1953 Belair 235 pilot bushing. A standard Dorman brand and one designed to convert an automatic engine crankshaft to a standard
1954 Chevy 1300 engine 235 (1959) 1955 (first series) Chevy 3100 engine 261 (1957) 1927 (other brand) Model T- engine 327 (1968)
