The main case is the same, so the mounting bracket should fit. You might have to adjust the length of the shift rods. Jerry
The Hurst "Dual Pattern" 3 speed shifter was the same, regardless of what vehicle it was used with. Hurst sold an "adapter kit" to make it compatible with whatever vehicle it was used in. We called it "The Hearse"- - - -because it buried so many transmissions. Not the fault of the shifter- - - -mostly the idiot hanging onto the knob! Jerry
I have the new 3 speed shift installed but am about at the end of adjustment on the linkage. It operates fine . Just a might short. Are longer ones available?
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
