1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
Hi all!
I trailered my 58 Apache home in July and am in the process of tearing it down to restore from the frame up. I have started looking at replacing the existing SM318 with a modern alternative. The tranny will be bolted to a sbc crate. Likely transmissions will be a Tremec TKX manual or a 700R4 auto. I’m beginning to think the existing low hump trans tunnel is gonna need to change. I would appreciate input about this issue so the mod can be made during steelwork if necessary. The SM318 fit easily with the low tunnel.
Thanks! Kevin
1958 Chevy Apache - "Stella"
"Start to finish w/upgrades"
'58 GMC 100 series cabs had 3 different Transmission Floor Pan Hole Cover options, depending on what transmission was installed. I assume that the Chevy body had the same options. The one for the 4 speed tranny would obviously have a hole for the shifter. Maybe the HydraMatic pan would provide more clearance??
From experience the “Low Hump” transmission cover will need modifications to fit either conversion.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
That cover plate is my existing setup. Only a small hump in the front. It’s the same plate for the original hydromatic supposedly. There is one other GM option for an original four speed tranny
https://www.autometaldirect.com/pro...YRQeBaelUL3fI9cLGAnJAjitaKwaAj9pEALw_wcB
If not this 4 speed plate, fabrication will be required as the back of the plate comes up against the seat munting rib.
I included a pic of my existing plate. It’s held down with 9 screws.
Transmission hump/cover plate
I'm pretty sure the 4 speed cover is no taller. It just has a cut-out for the shifter.
The Truck Shop catalogue shows a floor pan with a taller hump for a 4 speed on TF trucks. Likely other suppliers have them as well.
However, I have no idea that this will work with a later auto trans.
Fred
You want something flat to mount either shifter to M or A.
Hump you will be fighting. That tremec looks like to shifter is too far back for a TF.
The 700R4 can use a cable and mount anywhere.
~ BD.
