| | | Forums66 Topics128,212 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2023 Posts: 1 Moderated | | Moderated Joined: Aug 2023 Posts: 1 | Hey! New to the forum, never been on one before. I have a 1964 C10 getting rebuilt shortly. Long story short, I was rear ended pretty badly a couple months ago. I'm fine, my truck is a different story. It's currently a step side, I want to change it to fleetside for a different look. Having trouble locating a box. Is LMC the best choice or there is a place close enough to me I can order parts from. Located in Ontario Canada. Would appreciate any advice on what direction to take. I think finding parts from originals is a little difficult around here.
| | | | | Joined: Sep 2020 Posts: 453 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 453 | Have you looked at Mar-k bed parts? Long time supplier to members of this site….
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | Welcome to Stovebolt forums.  Mar-K could help you out with stepside, but unfortunately don't have the outer panels for fleetside trucks.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 6,056 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,056 | I will 2nd that Welcome to Stovebolt!  As you are mighty close to New York state, you may have better luck than you think in trying to locate a fleetside bed. You just have to deal with the cross border purchase requirements, but maybe worth the effort and cheaper than trying to import from afar??? Take a look at Craigslist, FB Marketplace and maybe even Kijiji and you might be pleasantly surprised. You could also place an ad here in our own Truck Parts Wanted section of the Stovebolt Swap MeetLooking forward to more conversations in the forums!  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2019 Posts: 35 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 35 | Hi, Agree. Welcome aboard. Jim Carter Truck Parts, Aspen Auto parts, 4, 5,6 chevy truck parts and LMC are all pretty good for used parts, except LMC (mainly only new). All these are located in KS or MO, except for aspen.
FB marketplace is great for local parts near you, i've found many parts that way.
Good luck | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I have seen people selling beds and parts of beds for what I would consider reasonable if you are looking to keep original metal.
If not someone posted a while back about a place that makes a complete cab for these trucks. I bet them make bed parts too. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Don't overlook trailers made from these beds, the old truck konked out and they just cut the frame, bent it together and make a trailer out of it, I have purchased several and usually in decent shape except for the wood
You Learn more Listening than Talking
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | If you do pull the trigger on an aftermarket bedside kit, mock up the whole thing before you paint anything. You will be surprised. They are close, but if you want it to fit perfectly some massaging will be required… ie metal work.
Don’t paint it before you do…. You might be very sorry otherwise. | | | | | Joined: Jul 2022 Posts: 90 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 90 | I just bought a bunch of stuff from autometaldirect. The shipping was about $1000 less than anywhere else. Got full bedsides, wheel tubs, rear window and some others. Should be here monday so ill see how it looks.
59 chevy Spartan 100, former firetruck 348ci with spicer 5 speed and electric rear
