2 members (ronsway, 1 invisible), 115 guests, and 4 robots.
Topics128,172
Posts1,057,035
Members48,458
#1514564 08/25/2023 10:22 PM
Hello all.
I recently hit substantial completion on my 1941 3/4T GMC PU but have yet to hook up the original gauges. I may have an issue with the gas tank sending unit. I converted the truck to 12v and have the 6v resistor to place on the hot side of the gauge. However, when I purchased my new gas tank and sending unit, I ordered a 12v sending unit, not knowing the wiring configuration at the time.
Now knowing the sending unit gets its juice from the gauge, it seems the 12v sending unit will not work. Is there an easy solution for this or do I need to purchase a 6v sending unit?
Any comments or help are greatly appreciated.
B Online: Content
What "12 volt" sending unit did you order? What is the full and empty ohms readings on the sending unit?
Sir Searchalot
Sir Searchalot
Sender is not voltage specific. There is no juice to them. Who sold you a "12V" sender? Just need to have a 30 OHM rating,
1. DO NOT run ANY voltage to the sender.
2. GMC's had positive ground.
3. Gauge has two terminals, one for voltage and one for the sender.
4. If you don't know about wiring, seek help here before wiring.
5. On your truck, the fuel gauge "frame" needs to be grounded. Probably has a lug or brass plate to touch dash metal when tightened up,
6. The sender terminal on older Chevy gauges is on the "F" side of gauge and may have a red warning tag.
I may be mistaken about the 12V sender. I purchased it from Tanks, Inc. but don't have the model number handy and it is in the tank now. From the comments received, the sender is neither 6v or 12v - just a sender that with an OHM rating. I do recall they asked me about the OHM rating which I gave them at the time - it has been a few years since the transaction so the details are a bit foggy and I can't find the paperwork.
My intent was to connect the sender to the red tag side of the gauge as you noted.
I should have mentioned, I also converted to a negative ground.
the gauge cluster is grounded.
If I understand correctly, the sender has no voltage or juice to it. if the ohm rating is correct, connecting it to the red tagged lug should provide a working gauge.
I appreciate the clarification and direction!
thank, John
Sir Searchalot
Sir Searchalot
Yes sir. thumbs_up Will provide a working gauge if the gauge is working and the sender is working and grounds are viable.
Recommend adding a wire from a sender flange screw to the frame for good ground.
Still learning here and all the help is much appreciated. I will add that ground as recommended.
thanks!
