| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I have a stock1/2 ton. Is there a simple upgrade/modification to the existing suspension to improve the ride? Not a Mustang II swap or anything that drastic. Just some minor mods or changes? I am just looking to improve the ride a little. Has anyone used Delrin Leaf Spring Liner with Lip between leaves? Does it make a noticeable improvement? Anything else I can do? | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | My best advice would be for you to disassemble, inspect, adjust, every moving part of the entire chassis front to back. Replace all worn parts. You will be surprised how well these trucks handle and ride once the entire suspension is restored to as-new condition. Spring pins and bushing. King pins. Steering box. Tie rods. Drag link. Wheel bearings. Adjust toe in. New tires. (I recommend radial tires.)
| | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | I’ll second Carl’s suggestions. Over the course of a year I pretty much completed everything on his list. One thing in addition was to remove the front springs, take them apart, clean each leaf on a wire wheel and install a liner between the leaves. The result of the above is a 3/4 ton ‘51 truck that rides and drives great. Understand, it’s not a new “today “ truck but it’s much better than its likely been since it had that 1st few thousand miles under its belt 72 years ago. Spring upgrade.RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
