5 members (Otto Skorzeny, 55shaker, MikeE, Cletus1950, Wally / Montana), 83 guests, and 3 robots.
Topics128,148
Posts1,056,809
Members48,454
Need to get me a replacement blower motor 12 volt for my 51 chevy truck fresh air heater. I bought the fan cage from truckshop in orange county. Need to put an order in to jim carter. Is the motor they sell a direct fit? What company sells the best motor to use on my heater? Not my heater but it's the same type of one I have.
benfur,
I have moved your post to the Interiors forum as it's the best place for further discussion.
AM sure many folks will be along shortly to offer info on replacement motors for your "fresh air heater". wink
BTW - be sure and come back and note if you are looking for a 6V or 12V heater motor to get the best possible answers.
Dan
~ Dan
1951 Chevy 3 window 3100
Benfur,
Please post a picture of your heater as there are many different style’s depending on maker and year.
Chris
I bought a 12 volt motor for mine from Classic Industries. There was something different about the mounting, and required some minor modification. I don't remember exactly what it was, but it wasn't much of a problem. It has worked OK so far, but hasn't been used much.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
I just (this spring) installed a fresh air heater system in my 49 and it came with a 6V motor that I replaced with a NAPA 12V - was over the counter even up in my remote neck of the literal woods:
NAPA M6478
Was an absolute direct replacement. Works great.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
Does it look like this?
Fresh air box from '51. The 12v replacement motor did come with motor studs that stuck out 2". I cut them off and rounded the studs to look like the old rivets, and shot black paint to blend. Repainted the housing.
I can't remember where I got the motor. Jim might have been where, but a fresh air 12v replacement is what I looked for.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
Chip O can you look at your heater and tell me what brand is the motor?
If you were rebuilding your heater and just needed to replace the motor I bet you could get it at any electrical supply house.. usually a lot cheaper..
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
I am still not positive where I got it from, but it came with the gasket and flex outer boot.
Chip
'Rusto-Mod'
O Online: Content
I see it's made from that rare alloy, Chinesium.
1950 Chevrolet 3100 (Ol' Roy)
Right now with cheapism flying rampant, almost everything has an Asian stamp of approval.
Chip
'Rusto-Mod'
Moderated by  ndkid275, Phak1
