9 members (Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, homer52, 2 invisible), 95 guests, and 3 robots.
Topics128,139
Posts1,056,451
Members48,441
#1514559 08/25/2023 10:07 PM
I took a long look at a stock ‘54 3100 today, mostly to expand my knowledge of the original mechanics. (I’m one of those HotRod guys…shudder…)
Everything made sense to me , as simple and straightforward as those machines are , except for the vacuum line leading to the fuel pump and from there through the firewall to (presumably) the vacuum driven wiper motor.
- Is the fuel pump not mechanical and driven off of the crank or cam?
- Why doesn’t the vacuum line for the wipers go directly to the wipers?
I know that these are pretty basic questions, but I’m asking because (as Red Green said - those three little words that men have such a hard time saying -) I Don’t Know.
O Online: Content
Fuel pump is mechanical driven off a cam. The diaphragm in the pump also creates vacuum which assists the windshield wipers. The fuel pump provides a steady source of vacuum as opposed to the on again off again wiper operation you get from manifld vacuum.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Vacuum wipers slow down, or usually stop altogether when the vehicle is pulling a hill or passing. The vacuum booster pump is in line with the intake vacuum to prevent the wipers from coming to a complete stop- - - - -if it works as designed. Most don't. Chevy was too cheap to put in a reserve canister with a one way valve to be a backup for the intake vacuum.
It is a second diaphragm on the pump that provides the vacuum for the wipers.
My 58 panel came with a vacuum pass thru bolt that mounted the
fuel pump. That line ran to the bottom of the fuel pump
with 2 vacuum ports underneath.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I am familiar with the wipers slowing or stopping or stopping when manifold vacuum drops … I am old enough that such things were common knowledge in my formative years.
I even understand the function of the vacuum advance!
Now that I think of it , such things were taught in hands- on shop class back then.
Ah, the good old days…
So there is a second diaphragm in the fuel pump , and it’s function is the produce vacuum for the wipers. The fuel pump itself is driven off of the camshaft.
I am a little smarter now than I was when I got up this morning,
Thank you.
‘Ski
