2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 12 Junior Member | | Junior Member Joined: Feb 2007 Posts: 12 | what parts are inter-changeable on 1 1/2 & 2 ton's with the 1/2 & 3/4 ton ? I know the fenders are different and have heard all else is the same ....I have a couple of 51 -6400's that I am parting out and wouldnt want to misrepresent anything to a buyer... if anyone has any info to share ,sure would appreciate it ...many thanks in advance | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I think one of the most valuable parts now is a straight cab, with no holes in it. Other stuff seems to be more readily available. As I understand it, the cabs are interchangeable at least until 1953.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The cabs are the same for 3000, 4000 and 6000 series trucks within any year. The 4000 and 6000 series trucks have different fenders, hood, inner fenders and related parts.
I've been told the grill bars are the same but the brackets that hold them in place are different, but I don't know the truth of that.
And of course there are running gear differences between every series.
Also be aware the '51 has unique doors. Turn-down handles with wing windows are a '51 only item.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2007 Posts: 21 Junior Member | | Junior Member Joined: Jan 2007 Posts: 21 | My '47 2-ton has turn-down handles with wing windows. Are you sure only '51 had them? I don't know if the doors on mine are the original doors since the trucks been repainted about 4 or 5 times. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The Advance Design doors are interchangeable from '47 thru '53.. so you could take doors off a '51 and they'd bolt on a '47, which is probably what happened in your case.
It happens quite frequently.. either a previous owner preferred having vent windows, or the original doors were shot and they just found a set of '51 doors and put those on.
'47 thru '50 trucks didn't have any vent windows, and had turn down door handles.
'51 was the first year for vent windows, and retained the turn down door handle of previous years.
'52 was the first year for the 'push button' door handle.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | One more important door swap detail is that the strikers are different for the push button door handles. Its easier to swap doors that have the same handle than to swap to different handles.
And yes Destry I am sure that only the '51 had both wing windows and turn-down handles.
