7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible), 211 guests, and 2 robots.
Topics128,086
Posts1,056,098
Members48,434
#1514269 08/23/2023 10:11 PM
Hello !
I have a factory 1949 3600. I need to change the rear diff so I can go faster than 2 miles per hour. I was told the truck has Farm Gears. Any suggestions would be great ,!
49.3600 #1514272 08/23/2023 10:19 PM
O Online: Content
What rear end do you have? Post stamping numbers if you don't know.
What transmission and engine do you have?
1950 Chevrolet 3100 (Ol' Roy)
3 speed, 216, looks like 3699535
49.3600 #1514278 08/23/2023 11:18 PM
3 Speed, 216 and looks like 3699535
49.3600 #1514284 08/24/2023 12:05 AM
O Online: Content
How fast will your truck actually go?
I have a 1950 216, 3spd, 4:11 rear end and I have no problem reaching 65mph. I can cruise on the interstate comfortably at 55-60 without undue stress on the engine.
When the truck came to me the owner said he couldn't go faster than 30mph and blamed it on the "low gearing." Of course it turned out that the clutch was slipping badly at about 30 mph and on any hill.
It also had crappy 15" wheels on it with tires of too small diameter. They were also too wide. You could barely steer it.
Installing a new clutch and original size 16" wheels an large diameter tires made getting up to 60mph easy as pie.
If your truck can't reach 55-65mph, you have problems other than a low geared rear end.
49.3600 #1514288 08/24/2023 12:16 AM
But Otto's truck is a 1/2 ton with a 4.11 rear gear while 49.3600 is a 3/4 ton probably with 4.57 gears. Don't know what his rear tire diameter is, but if you assume 30 inches it would take 3072 RPM to get it to 60 MPH. Not impossible, but certainly a scary engine speed for someone who isn't deaf, young or used to abusing his 70+ year old engine.
49.3600 #1514294 08/24/2023 12:36 AM
O Online: Content
OOps, sorry. Too many different trucks on here. My mistake. Seems like there was a '49 3100 that needed something.
49.3600 #1514332 08/24/2023 11:55 AM
Standard 3600 would be a 4.56 rear axle ratio (mine was), but I bleieve there was an optional rear end that was even higher numerical ratio (5.??) that he may have.
Regardless the tire size has a significant influence so it will be helpful to hear what he actually has.
1949/50 3600 Project
Follow in Project Journals
49.3600 #1514340 08/24/2023 1:22 PM
24601
If that rear axle in question is an HO52, then the3/4 and 1-ton axle upgrade Tech Tip will most likely have what you need.
chug
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
49.3600 #1514391 08/24/2023 8:43 PM
My Apologies to everyone trying to help. The truck is a 4 speed and the tires are 7.00-15. I was told that the truck was built with Farm Gears from the factory ?
Correct, in 1949 there was an "RPO 3600" that had 5.14 ratio rear axle gears.
Here's a page from the 1949 Vehicle Info Kit with that stuff highlighted. It's possible that people referred to the 5.14 ratio as "Farm Gears".
It should be a fairly simple swap to the more common 4.56 gears.
49.3600 #1514425 08/25/2023 12:25 AM
My 47 3600 has the 4:56 rear end. It is in very good condition so I opted to put a Gear Vendors overdrive behind my SM420. It gives me a 3.56: 1 final ratio. My 235 rpm is very comfortable 2400 at 60 mph. I have the original 8 bolt 15" rims.
1947 3600 Chevy
49.3600 #1514486 08/25/2023 12:41 PM
What is the outside diameter of your tires? 7.00x15 sounds like they would be pretty small compared to the original making your engine vs. vehicle speed issue worse. My '50 3600 tire size is roughtly a 34.5" outside diameter. If your tires are closer to 30" your engine speed will be more than 10% higher for the same vehicle speed.
