4 members (NJC, HandyAndy, Oswald, 1 invisible), 137 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
I have a 1958 fully restored Apache 31. The three-speed (on the column) transmission in my truck is connected to a 235 ci motor and both were in the truck when I bought it unrestored in 1986/1987.
I would like to know if anyone can tell me what transmission I have by looking at the attached photographs.
1958 Apache Transmission
Sure is clean under that truck.
What you have is the basic standard 3 speed transmission. The official name /number is a Muncie SM 318. It has a non syncro
first gear and was used in both cars and trucks with some configuration changes from 55 through 67.
Fred
Note: That one appears to have a 64 case according to the date code.
Thanks Bill
RFS56trk,
Thanks for decoding for me. Two questions, what does the 64 mean for the casing and what told you it was a Muncie and not a Saginaw?
A Saginaw case is considerably longer, and the side cover has 7 bolts instead of 4. It also has a synchronized 1st. gear. The Saginaw 4 speed uses a very similar case shape, and Reverse is moved to a different shaped rear housing to make room for the 4th. forward speed in the main box. Borg-Warner did something similar back in the 1950's with their T-85 heavy duty 3 speed and the T-10 4 speed.
As HRL stated 4 bolt side cover units are Muncie's even though some of them were made in the Saganaw plant.
The transmission you have is likely from a Nova or Chevelle with the correct truck side cover. A 64-66 truck would
have had a short tail housing. (except for overdrive units). GM changed the gear "pitch" in 64 and none of the
internal components interchange with the 63 and earlier units. It may be a bit more "heavy duty" than the earlier
transmissions as some of the gears are slightly wider.
Fred
