7 members (Hush, Joe W, Peggy M, Jon G, Gray_Ghost, Guitplayer, 1 invisible), 160 guests, and 2 robots.
Topics128,101
Posts1,056,179
Members48,436
#1512899 08/14/2023 1:08 AM
Looking at it and can only assume that you have to unbolt the rod to be able to change the felt.
Thought I’d ask before taking things apart.
Also, does anyone have a source for original sized replacements. The ones I got from classic parts are smaller by about an inch and thicker than what’s there.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1512907 08/14/2023 1:53 AM
Yes, you'd have to unbolt the pedal itself to install the felt, unless you cut the seal and try to jam it into the floor pocket. I assume you're talking about the seal and not the bumper that goes on the pedal swing arm.
T-Doug #1512908 08/14/2023 1:57 AM
Yes, I believe you do unbolt the pedal rod, pull it up into the cab, slide felt into its place and then run the pedal rod back thru the new felt's hole. If too thick, could you simply pull a couple layers worth of the material to decrease the thickness? If the width and or height is wrong, especially being too small, then that might be a bear to correct without getting another one.
Craig
T-Doug #1512962 08/14/2023 5:39 PM
Hmmm, I just got in a rubber floor mat.. I think I'll wait until after I deal with the new clutch to put the mat in.. then I can cut a hole for the brake and clutch pedals at the same time and install that mat..
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1513051 08/15/2023 2:17 AM
Sounds good. When I got my rubber mat, I believe I cut a slit from each brake and clutch pedal hole up to the steering column hole, making it easier to remove and install the rubber mat. Don''t think it came to me that way. Since then a couple times I needed to work on the flooring of the cab, it was much easier to remove the rubber floor mat with these slits in place. Food for thought.
Craig
T-Doug #1513060 08/15/2023 2:39 AM
Isn't that how it was done at the factory?
1950 Chevrolet 3100 (Ol' Roy)
T-Doug #1513074 08/15/2023 11:29 AM
AD Addict & Tinkerer
If your plan is to make the mat easily removable, there are other places you would need to slit such as the accelerator pedal and emergency brake. Take a look at the picture of mine before the pedals went in and you'll see what I mean.
Phil
Project Journals
Stovebolt Gallery Forum
T-Doug #1513091 08/15/2023 2:46 PM
Mine from a few years ago. I slit the felt for the rods and when inserted into the pockets it closed the gap and held them in place. From way up north; Alabama
1952 Chevy Pickup Truck
I stand corrected, after going back out to the truck and examining the slits in more detail, no way I could have done that good.
Craig
T-Doug #1513400 08/17/2023 8:33 PM
I'll likely do it the way papa has done his.. slits over to the emergency brake and release shouldn't be noticable and I can still roll it up to get to the master brake filler hole.. battery box side doesn't have anything so can roll it back easy enough if I need to get to the battery..
I'm going to put insulation down before the mat goes down to keep some of the heat and noise out..\
Working on getting the clutch and pressure plate in before I can tackle this one..
Thanks for all the feedback, it helps.
Doug
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1513578 08/19/2023 11:20 AM
For me, with age came some small amount of wisdom; I was not going to disturb nearly 70 years of unmolested dirt and rust to remove those things to install the floor mat. For my use it has served me well. Enjoying your posts.
Moderated by  ndkid275, Phak1
