Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
#1512657 08/11/2023 7:43 PM
Anyone have some pics of their system hanging around? I got my pipe and electric cutouts. Need to start designing something that is going to work with the lack of real-estate under these trucks.
My plan is to exit under the step with a long rectangle tip kinda like the mid 90s camero's.
I need to find a small ultra quiet muffler yet. cutouts will bypass muffler and tie back into exhaust. Long story short there is going to be allot going on under there.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
On the round track cars with limited ground clearance under the rocker panels, we used to split a piece of 2" exhaust tubing down the middle and splice in a TIG welded 3" wide piece of 16 gauge flat stock top and bottom. It ended up making an oval exhaust pipe that transitioned to the header collectors with a cone shaped adapter, which was also fabricated in the shop.
Fox Offline
Here’s what I did with my 70.
It tucked up tight. Lots of room for a cutout under the cab. We will see how how heat dissipation goes.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1270083/11.html
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox, can you point us to a post number? You have a bunch of great pics there but I don't see the exhaust routing.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Fox Offline
It starts on post 1389110.
Check out pages 10 and 11 of the build thread.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
The page numbers render different based on user settings.
Here is a link directly to the first exhaust post: https://www.stovebolt.com/ubbthread...ndpa-s-1970-c10-rebuild.html#Post1394000
Where do you buy the flanges to create the boltable joints? I haven't looked locally yet.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Started playing around with this yesterday. Going to have to insulate hyd clutch lines on this side and the starter on the other for sure.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Fox Offline
Thanks Fibonachu.
I got them from Summit.
https://www.summitracing.com/parts/sum-694925
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
