3 members (k2handyman, Youngin' Tut 59, 78buckshot), 74 guests, and 3 robots.
Topics128,030
Posts1,055,418
Members48,422
#1512550 08/10/2023 3:31 PM
I have a '41 1/2 ton PU and am converting to 12 volts. Will the gauge in the dash continue to work after the conversion,.
ronsway #1512558 08/10/2023 4:54 PM
Which gauge are you asking about?
The answer is "it depends"
Do you have a completely stock cluster?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
ronsway #1512560 08/10/2023 4:57 PM
Yes stock cluster. Will the amp gauge work.
ronsway #1512573 08/10/2023 7:08 PM
Insomniac
Insomniac
Yes, the amp gauge will still work if wired correctly.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
ronsway #1512578 08/10/2023 7:39 PM
Amp gauge will work fine. It has nothing to do with voltage. You will get mixed answers on fuel gauge. Some guys say they did nothing and there 6v gauge runs fine on 12v but most don't have that experience. I chose to replace it with a 12v gauge. Most will just get a resistor to step down from 12v to 6v. Obviously oil pressure gauge is not impacted.
Dave from Northern Kentucky
My 54 3100
ronsway #1512598 08/10/2023 11:48 PM
Sir Searchalot
Sir Searchalot
There are 1/2 the amps on 12V. It will be OK and still show charge/discharge. Samples a small percent and bussbars the rest (shunt).
If the amp gauge has a light, all bulbs must be changed including any dash light bulbs....and you probably know all the rest.
ronsway #1514214 08/23/2023 6:01 PM
I am doing a similar conversion and looking for what wattage the dash gauge bulbs should be?
Haasman #1514216 08/23/2023 6:08 PM
The gauge cluster bulbs are 1 CP #51 in 6v. A #53 12v bulb would be the replacement, according to this.
ronsway #1514319 08/24/2023 4:54 AM
How many bulbs should I get? There are the gauges, the ignition key light and the heater fan control. 7 bulbs?
ronsway #1514662 08/27/2023 12:21 AM
In my 54 the hi beam and turn signal indicator in the speedometer cluster where a smaller bulb than the other cluster bulbs.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
ronsway #1515283 08/31/2023 4:24 AM
Still working on the 12 volt conversion. What size 12 volt battery do you guys recommend? CCG? Group? Manufacture??
ronsway #1515288 08/31/2023 11:10 AM
Whatever fits in the spot you intend to put it. Get the dimensions of your battery box and start hunting.
Brand doesn't mean anything anymore but some people swear by Interstate.
More important than Group or dimensions are the Cold Cranking Amp figures.
1950 Chevrolet 3100 (Ol' Roy)
