1 members (MikeE),
70
Mod | | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | I have a '41 1/2 ton PU and am converting to 12 volts. Will the gauge in the dash continue to work after the conversion,. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Which gauge are you asking about?
The answer is "it depends"
Do you have a completely stock cluster? | | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | Yes stock cluster. Will the amp gauge work. | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Yes, the amp gauge will still work if wired correctly.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Amp gauge will work fine. It has nothing to do with voltage. You will get mixed answers on fuel gauge. Some guys say they did nothing and there 6v gauge runs fine on 12v but most don't have that experience. I chose to replace it with a 12v gauge. Most will just get a resistor to step down from 12v to 6v. Obviously oil pressure gauge is not impacted. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are 1/2 the amps on 12V. It will be OK and still show charge/discharge. Samples a small percent and bussbars the rest (shunt). If the amp gauge has a light, all bulbs must be changed including any dash light bulbs....and you probably know all the rest.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2010 Posts: 22 'Bolter | | 'Bolter Joined: May 2010 Posts: 22 | I am doing a similar conversion and looking for what wattage the dash gauge bulbs should be? | | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | The gauge cluster bulbs are 1 CP #51 in 6v. A #53 12v bulb would be the replacement, according to this.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2010 Posts: 22 'Bolter | | 'Bolter Joined: May 2010 Posts: 22 | How many bulbs should I get? There are the gauges, the ignition key light and the heater fan control. 7 bulbs? | | | | | Joined: May 2023 Posts: 443 'Bolter | | 'Bolter Joined: May 2023 Posts: 443 | In my 54 the hi beam and turn signal indicator in the speedometer cluster where a smaller bulb than the other cluster bulbs.
Doug 1954 Chevy 3100One problem solved doesn’t seem to shorten the list Montgomery, ALIn Project Journals | | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | Still working on the 12 volt conversion. What size 12 volt battery do you guys recommend? CCG? Group? Manufacture?? | | | | | Joined: Oct 2021 Posts: 6,698 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,698 | Whatever fits in the spot you intend to put it. Get the dimensions of your battery box and start hunting.
Brand doesn't mean anything anymore but some people swear by Interstate.
More important than Group or dimensions are the Cold Cranking Amp figures.
1950 Chevrolet 3100 (Ol' Roy)
