1 members (klhansen), 119 guests, and 2 robots.
Topics128,151
Posts1,056,997
Members48,460
So I got this home, and after oiling the cylinders and filling with oil and turning it over,
it has spark and fires a bit. This engine was obviously in use as a stationary engine in it’s last
incarnation. Amazingly the coil, points etc are working. With a solid state regulator, alternator and volt
meter rigged up to it. Has a hand lever to engage the manual starter.
The starter was turning , but sluggish, enough to get a brief fire with hand priming.
I took it apart and the brush brackets were frozen on one side and broke off .
I have another starter to try tomorrow.
I got some numbers off and would like help dating /identifying this engine.
Block casting on passenger side: GM 3769717
Stamped by dist. : 27213
Head: 3836848
GM 3
This is in all likelihood, a Canadian engine.
By the large vacuum connection on the manifold, it would seem to be a truck, hydrovac line .
The PCV rig looks stock.
So, any help from you great people will be appreciated!
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
By the way, you’ll notice I’m using the Stovebolt engine cradle!
And the grandson loves it!
~Charley
“Bud”
1954 GMC 3 ton 302
Steelonsteel,
Block casting# 3769717 decodes as a 1959-62 "261", rated at 135 HP. Definitely a US Chevy engine I do believe.
Can't offer much for the serial# as the picture doesn't show the whole pad, which may need a bit more cleanup to fully expose all the the stamped digits. Would also help if you can locate and report the "date" casting info on the side of the block directly above where the starter mounts. That and the full serial number info will help better pinpoint your engine info.
The head casting# 3836848 decodes as a 1956-62 "235" with 4 bolt rocker cover and large diameter temp sending unit hole in the head.
PCV setup (for the most part) is correct for the "261". I think the vented cap on valve cover is a transplant from something much later and the large vacuum port manifold and lines definitely make this a "Big Bolt" contender.
Nice to see you have such an enthusiastic helper. thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
Well, thanks Dan.
I cleaned the number pad some more and it really seems
to only be this number of digits, except: 272 I 3, the letter I.
And in the starter area, the captain’s bars, is all I see .
With this 235 head, then , is this the much desired 848 head mod?
Charley
~Charley
“Bud”
1954 GMC 3 ton 302
Charley,
It could very well be that what you have is a replacement block, which wouldn't have had an actual vehicle serial number stamped, but could have been stamped at time of purchase/replacement to match whatever the owner needed it to.
It would certainly appear that someone did go for the "848" head mod, or could have been just a replacement out of necessity if the original head became unusable? Can only guess from what is there.
looks like you found a "keeper"! thumbs_up
Dan
~ Dan
Right. Thanks Dan, yes, I am feeling good about this engine.
Appreciate your help!
~Charley
“Bud”
1954 GMC 3 ton 302
Insomniac
Insomniac
Interesting find.
Apparently, Canadian 261 Pontiac engines have the 848 heads. Reference: https://118110.activeboard.com/t60840366/261-canadian-pontiac-with-848-heads/
I'm guessing that the stamped serial numbers are a different format from the US format. (digits only)
This thread should be of interest to you:
https://www.stovebolt.com/ubbthread...ontiac-261-vs-truck-261.html#Post1028317
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Gord,
Thanks for providing this extra insight and schooling on the "Canadian" 261.
You have added to my knowledge bank!
Charley,
Sorry if my "US" 261 block and 848 head info may have caused any mis-identification of your engine. Will be interested to hear more about the engine as you may get into it. Also curious to know what made you think the engine was of Canadian origin in the first place???
Dan
~ Dan
Well, Dan, it was located in Victoria BC.
The whole 848 saga is not crystal clear, even after reading the several discussions,
but I will pull the head as I go, and hope there’s no cracks etc.! And looking for solid lifters. I hope it will find a home in the ‘54 !
The spark plugs looked so good and all the same that’s a good sign. I’ll show progress on it as it goes. Thank you for
the interest!
~Charley
“Bud”
1954 GMC 3 ton 302
Clean the block between the captains bars and the engine code/serial number down low near the horizontal ridge and see if the date code raised letter/numbers are hiding there...it should look something like this, B 15 9 (Feb 15, 1959).
Your head should also have a date code...
Mike B
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
.... And looking for solid lifters. I hope it will find a home in the ‘54 !
IF it IS a Candian AUTOMOBILE Engine - possibly from a Pontiac Parisienne - then I believe it will have hydraulic lifters
https://en.wikipedia.org/wiki/Chevrolet_Stovebolt_engine#261
Quote
The 235 and 261 truck engines were also used by GMC Truck of Canada (GMC truck 6-cylinder engines were also used in Canada). The 1955—1962 full-size Canadian Pontiac car had a standard 261-cubic-inch engine that had hydraulic lifters.
I had been looking in CA for a 261 myself - I'm in WA and not too far from BC - looked for a while but just bit the bullet and bought a complete (with carb, maniolds and all ancillaries and trans) sweet running 235 out of a 58 DelRay in Vancouver.
Side Story - When the Immigration Officer asked how long I had been in Canada, and I replied, just a couple of hours, she gave me a suspicious look and asked why so brief; I pointed to the engine in the back and explained I had bought it and only there long enough to load it and return grin
'51 Chevy 3100 Truck - OEM 216 Engine; three speed column shift transmission
6 Bolt disc conversion with dual master/vacuum booster
12V alternator conversion.
235 engine in waiting grin
