2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
Thought I posted pics of this stand I made years ago back when I wanted to work on my SM420, but can't find any records of such. So, here we go........
While going thru the various boxes of truck parts, I found this stand that I produced back in 2012 which while I had my gearbox out of the truck, I wanted to work on it but did not like the way it sat on my work bench, so somehow I came up with first the front support bar but then didn't like the downward angle towards the back and saw the drain plug looking for some attention, so I added the rear support. So some winter while you're kinda bored.......
Cheers
Craig
Is that T leg threaded into a hole on the transmission?
1950 Chevrolet 3100 (Ol' Roy)
B Online: Content
I think the drain plug is 1/2" NPT.
Ok. I didn't quite understand what he meant. That's pretty good.
Yes the T leg threads into the drain hole. It isn't as important as the front support. Just another toy
Craig
very nice, would be good for storage of some of the units I've got rat holed!
BC
1960 C60 pasture art
Insomniac
Insomniac
Cheers
You did post those pictures. I remember seeing them when I was working on my transmission. Here's the post:
https://www.stovebolt.com/ubbthread...947/sm420-bench-support.html#Post1396947
Gord 🇨🇦
1954 1/2 ton 235 4 speed
This is awesome! I also noticed the bicycle pedal toe strap. There are lots of other uses for those things.
Moderated by  MNSmith
