8 members (Hanks custodian, FAST55, Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L.), 82 guests, and 3 robots.
Topics128,075
Posts1,056,003
Members48,433
#1512169 08/07/2023 1:53 AM
2 Offline
I have a fairly original 49 that has what I think is the original tank. Maybe not. It has a drain plug hole on the front passenger side (bottom) of the tank. Anyone know what the thread size is? The plug is long gone. Thanks
I can check a tank that I have to see for sure, but my guess would be that it is most likely a pipe thread in order to seal the hole tightly. I have a look at mine to see if I can determine a size.
Life is good on Windy Ridge!
AD Addict & Tinkerer
My tank located behind the seat is 1/8” NPT. However it’s located on the bottom center of the tank and not the passengers side.
EDIT: my appologies, I missed the part that this is for a panel. Different tanks. The drain however,might be the same thread.
Phil
Updated to: β€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
Professional procrastinator
I have 2 of those tanks here. I will see if I can get the plug out for you. They are not so easy to remove after 70+ years
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
It is going to take some soaking and some heat. Neither one are budging.
