7 members (Otto Skorzeny, Tom McGrath, Gdads51, TPR57C, 32Fordpuchoptop, Wickedbass, 1 invisible),
97
Mod | | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | The tranny in the old Fire Truck has a Chelsie PTO. When I got the truck home it sat for a while. Noticed a lot of tranny oil on the ground. I now have it on a bench and am wondering what kind of gaskets/seals I should replace. Doesn't look like many places where oil could leak out. Anyone messed with a '35 4speed with PTO? | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Is there a packing gland on the PTO out put shaft? If so it may need fresh packing or tightening. My '31 has a packing gland but I'm not familar with a '35. | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The only gasket on the trans that would leak is the transmission to PTO (6 cap screws hold the PTO to the side of the trans). Any other leakage would be in your PTO. I am not familiar with the Chelsie as I have both Heil and Garwood units. Not much to them only a seal to the output shaft and the gasket to the transmission.
34 & 35 trucks are the greatest
| | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | The output shaft on this tranny has a long one inch housing that goes into the bell housing. There 1/4 inch sloted bolts that hold this onto the tranny. Apparently sometime before me, this housing broke or cracked and has been welded. I noticed what appears to be a oil leak. Does this housing need to be leak proof? | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | John Boy, That is the packing gland. You should be able remove the bolts and slide the gland back on the shaft and add a couple of rings of packing like water pump packing and put it back together. Snug the bolts down fairly tight but not tight enough to break the ears off the gland, which is probably why it has been welded. | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | I got my ends of the tranny backwards.....the end with the problem is the engine side. This is the bearing retainer that the throw out bearing fits on. Some how it was broken and has been welded. Maybe when this old thing is on the road, I will be able to know the difference between the radiator cap and the tail board. | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | After I recognized the front from the rear I realized the reverse detent lever did not work. It is amaizing what a little WD40 can do. | | |
