2 members (Hotrod Lincoln, FAST55), 52 guests, and 8 robots.
Topics128,012
Posts1,055,315
Members48,419
#1436321 01/06/2022 7:02 PM
In what direction does the center bow on a 50 GMC go? I see that one side slips into the channel more than the other. Which side front or back or does it mater?
forman #1436328 01/06/2022 8:17 PM
Yours isn't the first time that question has been asked. I searched for the answer but couldn't come up with the answer.
My opinion is that it should go on with the edge you can see toward the rear. The upper slot would go on the front part of the headliner so you can tap it in place, then the rear part of the headliner goes in the lower slot. That way, the wind won't catch it and rip it out. wink
I'm sure someone will be along with a more solid answer. I'm interested in that I have the headliner install ahead of me as well.
Here's a pic: Link
[on edit] The Tech Tip says the rear half goes into the upper slot (that's reverse of what I said.) ohwell
forman #1436526 01/08/2022 2:45 AM
C Online: Content
In my '50, the bottom half of the bow is supporting the front headliner board.
Craig
forman #1440049 02/04/2022 4:27 PM
forman Put your rear headliner panel in,put the bow on the edge of the rear panel,then carefully install the main big panel. Keep it all pushed back and install your windshield garnish mouldings. Left and right tails go under the edges of windshield rubber. GOOD LUCK !!
cmayna #1512109 08/06/2023 4:36 PM
Moderated
Moderated
Yours is correctly installed from what i been reading on the forum
forman #1512162 08/07/2023 1:02 AM
I'll add that on a 54' the bow is the same as the one in the link provided by klhansen and the left side as shown in the view goes to the front towards the windshield. The front section is "staked" into the bow at the factory. If you look closely you can see the "dimples" in the bow. Take a thin cutoff wheel and skim those dimples so the headliner ( front section ) will fit into the bow easily. Once postioned and bottomed in the bow, take an 1/8" ball bearing and position it into each of the exisitng dimples in the bow using a piece of masking tape to hold the ball in place, and then using a pair of vise grips " re-stake " the healiner in the bow . This will keep it from coming out while you are installing it. Get the front section and bow installed and then position and install the rear section. There seems to be differences in the fit/quality of headliners. It took me two seperate attempts before I got it installed. THe second headliner came from The Filling Station and it fits nicely.
Headliner Installed view 1
Healiner Installed view 2
Ron - - Dusty53
1954 Chevy 3604
Moderated by  ndkid275, Phak1
