6 members (Uncles51, spanky, texas46, Hotrod Lincoln, Southerntruck, Steelonsteel), 69 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#1511874 08/04/2023 5:10 AM
Looking for some info. on two 235' chevy engine blocks. Basically, I need to know what year they were both built. Here are the numbers 3837004 and 3788307. I appreciate the help, thank you.
Ol'55 #1511876 08/04/2023 6:17 AM
Neither one of those numbers show up here.
There should be a number by the starter beginning with an Alpha character and 2 or 3 digits that indicate the date. The letter indicates the month and the next one or two the day of the month. The last digit is the last number in the year, as in 5 for 1955.
Ol'55 #1511888 08/04/2023 12:32 PM
According to my resources the casting# 3837004 is listed as for 1955-57 Chevy 235's with 4 different horsepower ratings (123, 136, 140 and 155) and notes it would have the "large WP hole" (Water Pump).
I didn't find your listed "3788307", but there is a listing for "3738307" (perhaps the number was misread?). The "3738307" is listed for 1958-59 235 with either 135 or 145 horsepower and notes specifically for a "truck".
As Kevin mentioned above, locate and post the "date casting code" info located directly above the starter location and we can better help ID these blocks. Should look similar to this info below:
CON 8 D 18 7 (CON 8 = Conveyor #, D = Month (April in this case), 18 = Day of the month (18th), 7 = Year (1957)
Hope this helps. wink
Dan
~ Dan
1951 Chevy 3 window 3100
Ol'55 #1511889 08/04/2023 12:50 PM
OK here is the other numbers E148 and the other one is hard to read. Thanks again.
Ol'55 #1511908 08/04/2023 6:21 PM
May 14, 1958
BC
1960 C60 pasture art
