1 members (Jimmie D),
110
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 10 | Setting up to paint some parts on my COE. Would like to use my new 14’x22’ shed as a booth. I don’t have power run to it so was thinking of just running a temp air line out to it with a regulator in the shed, how long of a run could I get a way with before running into air supply problems. My compressor is a newer 220 volt 80 gallon 2 stage. This would be used for fenders doors,
Let the games begin! | | | | | Joined: May 2015 Posts: 11,063 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,063 | You can offset length of the air line with larger size. It depends on your paint gun CFM/pressure demand. You could also pipe directly to the compressor and put the regulator at the end of your pipe where you connect your final hose and paint gun. Don't try to run 3/8" ID hose at the lower pressure, because you'll likely run out of air. As a WAG, I'd say you could probably use a 3/4" pipe at tank pressure.
If you can tell us how far you need to run, and what your gun demands, I could probably give you a better estimate of size needed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I'm running 60' of 3/8" hose around my house to my side work area. Filter and regulator at the paint area end. No issues to date. | | | | | Joined: Apr 2020 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 10 | The run from compressor to the point where I’ll have the regulator is a little under 125’. I was planing on running 100-125 psi from the compressor to the regulator. This is a temp set up so if I do this I wanted to run hose and paint and roll it up at the end of the day. Gun are all hvlp. Hose was thinking of 1/2”
| | | | | Joined: Apr 2020 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 10 | That’s some good info. Got me thinking more about loss of cfm at the end of the run. But looking at the tables in the link, I think I’ll be fine. Thanks for the info!
