Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (woodrow2002, cmayna, dt235sd, Thom75, 1 invisible), 111 guests, and 3 robots.
Topics128,290
Posts1,058,557
Members48,491
#1511747 08/03/2023 2:31 PM
I have a 1953 GMC with a 235 ci engine. Any idea of what type of rear main seal it has? It was rebuilt about 10-12 years ago.
What year is your 235 engine?
Brian
1955.2 3100 Truck
It’s a 1955 235 ci engine
Moderator, Electrical Bay
Then it most probably will have the rope type seal. The neoprene seal was developed in 55 but as I recall 1956 was the first year where the slot was machined to the right dimensions for it.
~ Jon
Correct. 56 pass car was first year for neoprene and the rear main cap was machined specifically for that seal, whereas the earlier motors had less precise, deeper, cavities for the rope seal.
Mike
1955 was a change over year.
Early engines used shims on the mains and the deeper seal groove, and later in the year engines did not use shims and had the shallower seal groove as mentioned.
My Blog
