2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
1 Offline
Can anyone tell me what the various Brake Fitting sizes (i.e. dia. & thread #) are ?...I also assume these are NPT or NPTF ?
'50 GMC 1 Ton Dually - Barn Find (sort of...no barn)
3B Offline
Hy 1950 FC253, I believe the brake lines are 1/4" with inverted flare nuts/fittings, there may be "banjo" fittings at the wheel cylinders and possibly the master cylinder as well, these use running thread "banjo" bolts to hold the inverted flare blocks in place, those use a copper washer on either side of the block to seal them, hope that helps.
1 Offline
Thanks 3B...I'm more interested in the rubber hose fitting sizes (see pic...white circle)
I'm going to guess that those are the same size as on a 3100. Thread diameter would be 7/16". The hose on my 3100 has a female thread with inverted flare seat.
Measure the OD of your existing tubing, it will either be 3/16" or 1/4"...like 3B I'm betting it's 1/4".
The 1/4 inch inverted flare nut has a 7/16-24 thread. So your brake hose will need a 1/4" inverted flare Female end at the frame to mate up with the 1/4" inverted flare nut.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
All,
Just a note that I have moved this conversation to the Driveline forum as it is the best place to continue the conversation.
Best Regards,
Dan
~ Dan
1951 Chevy 3 window 3100
3B Offline
Hy 1950 FC253, the brake hoses on your truck are all the same, they are Raybestos p/n BH4497. They have 7/16" X 20 male thread on one end and a 7/16" X 24 female inverted flare one the other end, they use a copper gasket to seal the male end of the hose, hope that helps.
