5 members (fonz8261, 78buckshot, Gdads51, Hotrod Lincoln, 1955 1 Series), 74 guests, and 2 robots.
Topics128,180
Posts1,057,067
Members48,460
#1511544 08/01/2023 11:19 PM
Does anyone know if this number off the carrier is the part# for it. 3697701.
Yes, the GM Parts Wiki says it's for a 54-62 1/2 ton except O/D & Posi
sub57,
I sent a reply to your Parts Wanted ad with other info based on an initial search of the GM Parts books I had at hand, not knowing about this casting number.
Now that you provided this casting number info, it turns out that that part has had a number of different GM Part numbers assigned to it.
Original GM# 3697701 shows as both the casting number and part number, after the originally listed GM# 3718011 (casting# 3707340) appears to have been replaced by it in early 1958 (I think?). Was listed for 1955-62 and some early 1963 1/2 ton axles.
GM# 3697701 was later replaced by GM# 3854311 (same part and application for 1955-62 and some early 1963 1/2 ton axles) - just a new part number.
GM# 3854311 was later replaced by GM# 3867832 (again same part and application as before) with another new number.
GM# 3867832 has since been removed form the parts catalogs as no longer available.
On a bit of good news, check out your Parts Wanted ad as I have added a new reply with a possible source I found after all this research.
Hope this is clearer than mud.
Dan
~ Dan
1951 Chevy 3 window 3100
Finally found all the NOS parts to reassemble the Chevy 1/2 ton non positive differential 😜. Thanks Dan and Klhansen.👍
Outstanding to hear that!
Are you (by chance) thinking of taking pictures and writing notes as you go through the assembly and reinstallation process??? headscratch grin
I detect an opportunity for the makings of a very useful Tech Tip! thumbs_up
Looking forward to progress reports and pictures as you may be able to share.
If you run into a question or concern, come on back and ask away! Very sure help will be available pretty quickly.
Dan
~ Dan
