Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#151155 02/24/2007 5:29 AM
Apprentice
Apprentice
on my 51 with the updraft carb setup the carb is leaking fuel from the bottom of bowl ...anybody have any ideas whats wrong
yaknow. water sometime gets into the fuel system and settles in the bottom of the bowl. when it gets cold.......
isn't there a plug in the bottom of some of those?
if you need a rebuild kit,or a NEW or rebuilt carb, call:
VAN'S CARBUERATOR AND ELECTRIC
KENTUCKY AVENUE
INDIANAPOLIS, INDIANA
they have what you need in stock. i'm not sure about shipping, but koolkar (bless his heart) lives only abut 25 miles from van's and has family in kentucky, so.........
1 Offline
Double check ,probly the float is to high or crap in needle valve and filling bowl to high. Just my 2 cents
restoring a 1946 coe wrecker.
Apprentice
Apprentice
there is a place in the bottom of bowl where its leaking that is bossed like maybe a plug whent in there but ive never seen another to know what it supposed to look like
Hi Low,(sounds funny)
I just came across the same thing. Is it leaking when running or when turning over. If it is running then it is a float problem. If it is while turning over it is unused gas and not to worry about. They make a place on updraft carbs cause the unused gas can't run up as it would be and if unused it needs to escape from the carb. My truck doesn't do it when it is healthy, just when I was turning it over a bit on first start-up some time back. Hope that helps.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
I had the same type of problem on my old farm tractor this morning. It wouldn't leak until it was shut off, but ran really rough. New needle valve and seat cured the problem.
Apprentice
Apprentice
it mainly leaks while sitting ...ive never seen it leak while running ...........
I think if the float is too high you will have a moist gasket and a little seapage around the seam of the two carb halfs.
1947 Chevy COE
Apprentice
Apprentice
it seems to be coming from the very bottom of the carb bowl there is a small inbossment there i almost thought there was supposed to be a plug there
It is probably a high float, but is your gasket damp? and the sides of the carburator moist? If not, then it should be internal. Could you have a pin hole in the casting? I have one in mine, but it doesn't effect anything where it is on mine.
1947 Chevy COE
