5 members (Shade Baby, 69Cuda, JoergK., WICruiser, 1 invisible), 146 guests, and 1 robot.
Topics128,175
Posts1,057,053
Members48,460
Both of my rubber lines for my oil filter are trashed. I know I can buy the from Jim Carter & shipping cost is almost the same as one hose. I get it, it takes material & time to ship items. However I have a Local auto parts store that can make hoses. I haven't checked on price there, but I have a feeling it will be much lower than ordering online. I am curious if these hoses have a metered port on the end that goes into the block for each hose. If so maybe I should just order them.
1953 Chevrolet 6400 Dually
Follow in Big Bolts
1985 Chevrolet K10
2008 Toyota FJ Cruiser
2008 Mazda Miata
2021 NuCamp T@b 320 S
Just take the old ones off and take them to the hosemaker. They'll be able to copy them. I don't think they're anything special.
1950 Chevrolet 3100 (Ol' Roy)
I had one break on the road (old and cracked). I just bought same diameter hose at flaps and took the fittings out (cut them off) of old one. Had two small hose clamps. Bam...all good. Was like that for almost a year. Then I got new ones.
If you need a quick fix. Or make your own that way.
Todd
****1/8 npt and 1/4 male inverted thread should be the fitting sizes
1950 Chevy 3100
AD Addict & Tinkerer
The metering is done in the oil filter. The standpipe, inside the filter has a 1/16” orifice that meters the return flow. No need for anything special with the hoses.
Phil
Project Journals
Stovebolt Gallery Forum
I used 1/8" soft bendable brake line. Now it's hard lines from the canister to the block. No more failed rubber lines.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Thanks everyone.
Follow in Big Bolts
1985 Chevrolet K10
2008 Mazda Miata
I also replaced my hoses with CuNi Tubing. Looks great and no more leaks!
Phil
Project Journals
Phil
Project Journals
Thanks, I just ordered everything to make these lines.
Follow in Big Bolts
1985 Chevrolet K10
2008 Mazda Miata
