6 members (Otto Skorzeny, R&S 51 GMC, KEVINSKI, Bill Hanlon, Swami29, Phak1), 100 guests, and 0 robots.
Topics128,125
Posts1,056,339
Members48,440
#1511357 07/31/2023 4:31 PM
I tried to get my work in progress running, which I haven't done in a few months. New battery, 12 volts to the stomp starter. Yesterday, the engine turned over a few times then suddenly nothing happened when I pressed the starter. Today, when I turned the ignition switch on it briefly moved the gas gauge then went off again. The headlight won't turn on either. I'm thinking the switch may be bad? That, and the wiring, is original to the truck as far as I can tell. An electrician I am not! Any ideas?
Thanks!
Buford, 55 1st series
1955 1st 3100
First, the lights are not wired through the ignition switch. If the lights are not working either it sounds like you have no ground or a bad connection at the battery for the positive. Check for power to the AMP meter. Everything runs through there.
Dave from Northern Kentucky
My 54 3100
B Online: Content
The stomp starter that doesn't work doesn't run through the ammeter. But I would start with both ends of both battery cables, like Dave said above.
Thanks for the advice. I'm going to replace both cables and will report back.
1955 1st 3100
Riding in the Passing Lane
I agree with the bat. cables, but are you sure the bat. has not discharged.
George
1972 Chevy c10 Cheyenne Super
Sir Searchalot
Sir Searchalot
Your title "no power to the ignition switch" says you have checked to see if there is power TO the ignition switch.
To reiterate what others have said:
1. As said, the ignition switch has nothing to do with starter not turning over. Batt pos cable goes to a big push button switch on top of the starter. Call that the starter switch. Foot stomp pushes lever to engage pinion gear on starter to flywheel gear. Foot lever also pushes on starter switch button to spin starter.
2. As said, the lights are not wired thru ignition switch.
3. Gas gauge is thru ignition switch.
4. Ignition switch turns on gas gauge and coil.
We can see that the problems are not ignition switch related. We can see that two are items are on a direct source of voltage, one is thru the ignition switch which is on a direct source of voltage. (Battery/generator or cables). You may not have any electrical components working.
First thing to do is put a volt meter on battery for a baseline. Should be about 12.6V. If you are not good at electrics and don't have a meter,You can jump it to see if troubles go away...or have it tested. Some FLAPS don't have the right tester. Some have the right tester but the wrong tester'er. smile. A guy at Autozone finally knew what he was doing recently. Oreillys not so much. I realize you said new battery. So logic, which is just an educated guess, says cables. Battery first!
Costco, where I buy all my batteries, now tests them when you bring them back for refund.
First thing to do is clean the ground wires. Especially the one from the neg battery post to the engine block/bellhousing. If that one has become non-conductive then chances are nothing else will work, either. Check the ground from the block to the frame. If that one is bad then no lights. Check the one from the frame to the cab. That one grounds everything inside the cab.
Make sure all your grounds are good before you throw money at it.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Thanks for all the advice. I replaced the cables and cleaned the grounds and she starts and the headlight works! Now onto rust repair....
55 1st 3100
1955 1st 3100
