2 members (RoadsScholar, Otto Skorzeny), 196 guests, and 3 robots.
Topics128,108
Posts1,056,231
Members48,436
#1510868 07/28/2023 8:37 AM
Noob quest = for my 59 3600
I got a set of 8bolt 15X8 … the rear tires are getting fatties (cause I’m into that)
The front however… anyone know the limit for how wide they can be without hitting anything during turns? 255s are likely too big I suspect
Are you keeping the stock front axle/brakes?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Presently I think yes… but I’m not dedicated to it.
Slightly on the fence with front disc conversion.
Maybe I should flip a quarter on that one
59 3E 3600
…the quarter says leave the front end stock
…unless i find a 8bolt 4x4 front axle and that thingy PTO for my tranny … and do that mod (with whatever brake setup that comes with it 🤷🏻‍♀️)
59 3E 3600
Going much wider than stock will affect your turning radius because the stops barely prevent the tires from hitting the frame. You can address that somewhat by getting higher offset rims, but that will put more stress on the spindles.
The 3600 has wide enough fender flares that you can stick out pretty far before you scrub them.
Do you mean PTO or Transfer Case?
Put big bolt front sheet metal on it, grill, bumper, hood, fenders, etc.- - - -it will look butt-ugly, but the tires won't rub the wider spaced fenders with the bigger wheel openings.. Avoid sharp turns at high speed, and increase your life insurance coverage in case a hairpin turn sneaks up on you.
75r15 is a given
215s up front
265s in the rear
59 3E 3600
These are 225-75R15 tires with the 3200 fenders. They fit fine.
You could go larger on the 3600 fenders if you wanted to.
225-75R15
Originally Posted by Fibonachu
These are 225-75R15 They fit fine.
👍 them pike out a lil bit 😸
-I’m going for that Ed Roth look… fat rears, skinny fronts… but with mud tires (my truck is evil)
59 3E 3600
