0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2023 Posts: 4 Moderated | | Moderated Joined: Jul 2023 Posts: 4 | Any ideas out there about what Idle vacume should be?? We have what appears to be a 261 in a 1950 C3100 compression seems ok 90-140 psi but the Idle vacume is around 12 in.
Bob O'Neal
| | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | My 250 will idle around 17 in. 12 seems a little low. | | | | | Joined: Mar 2014 Posts: 4,485 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,485 | Hello Bob and welcome to the site. Your compression is between 90 and 140? Please tell us more...you can write in German if you need to do that. Your compression seems to be a large range (between high and low).
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2014 Posts: 3,684 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,684 | My 235 idles at about 21 inches of vacuum, on my gauge. I’ve never checked my gauge against another to see about accuracy.
Please post readings of compression for each cylinder. Jon is right, that is a very wide range.
1951 3100
| | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | Ignition timing will have a large effect on vacuum.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Compression readings for all the cylinders should be within 10% of each other. It sounds like you have some valves that aren't sealing well, or worn piston rings. Either problem will cause low vacuum. Is the vacuum gauge steady, or does it fluctuate while the engine is idling, and does the gauge stabilize when the RPM is increased? Try advancing the ignition timing a few degrees and see if the vacuum rises. Jerry
| | | | | Joined: Jul 2023 Posts: 4 Moderated | | Moderated Joined: Jul 2023 Posts: 4 | Hi, Thanks for the responses!!! I am a Expat living here in Germany and have a small shop that only deals in American cars.
The compression is 90,90,90,100,140,100 I opened up the valve lash to 12/14 hot and the truck still only has 12in vacume. Timing is at the ball. Thanks again , Bob
Bob O'Neal
| | | | | Joined: Jun 2021 Posts: 157 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 157 | Hi Bob,
my 261 has a similar vacuum reading, but it's not a stock cam - are you sure you have a stock cam?
Greetings from Augsburg, Frank
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Elevation factors into manifold vacuum as well. If compression test was done with engine at operating temp I'd next do a 'wet' compression test or a cylinder leakage test .
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2019 Posts: 4,478 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,478 | Elevation factors into manifold vacuum as well. If compression test was done with engine at operating temp I'd next do a 'wet' compression test or a cylinder leakage test . For those ‘bolters that don’t know what a wet compression test is, after your initial readings, inject about a teaspoon of oil into the cylinder the repeat the test. Don’t inject more that a teaspoon of you may get false results. If the compression comes up significantly (over 10%) it’s the rings. If no increase, it’s the valves.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The 140 reading is way above normal. Try putting a bore scope into that spark plug hole and look for lots of carbon deposits. A tablespoon of extra carbon in a combustion chamber can raise the compression ratio by up to about half a point, depending on the size of the chamber. Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | My 261 with 848 head off a 235 reads 145-155lbs. hot at 2500 ft. altitude. It also has a hotter cam that should drop the cranking pressure some. The 235 with the same head and cam was about 135-145 hot. Idle vacuum on both engines is/was ~ 12in.Hg at ~700RPM Less if pulling the A/C compressor or if the alternator is loaded. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
