5 members (Hotrod Lincoln, Hanks custodian, Otto Skorzeny, Woodcmiami, 1 invisible), 145 guests, and 7 robots.
Topics128,077
Posts1,056,031
Members48,433
#1510593 07/26/2023 3:49 AM
Anyone know where to find the adjustment rod for moving the seat.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
If you're talking about the rod that extends across between the two seat tracks, I posted dimensions for making one from steel rod available from the hardware store.
Stand by and I'll track down the thread.
OK, here's where I posted it. Link
I ended up using some 3/16 coated cable and a turnbuckle for mine and it works ok.
I’ll go back and cut the excess wire off it sits for a while.
1954 Chevy 3100
Montgomery, AL
In Project Journals
Good solution. thumbs_up It just needs to transfer the pull on the driver's side lever over to the passenger side.
Moderated by  ndkid275, Phak1
