2 members (Hotrod Lincoln, Jimmie D), 55 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Hello,
New guy here, where would I post a carburetor question? 1953 model B carb on a 216, thank you, somerust
Jim D.
1953 chev 3800
bicycles 'n junk
mental fog
somerust,
I have moved your post to the Engine Shop for more conversation and help on the topic.
Dan
~ Dan
1951 Chevy 3 window 3100
Moderator, Electrical Bay
Hi and welcome to the site! What is your question?
~ Jon
ok thanks for redirecting my post.
I am learning how to use this cool site; computer use difficult to understand. unable to send a pic.
Rebuilding a model B carb that is on a 1953 3800 216.
How do I rotate the pump discharge guide, so I can remove it, the spring, and the ball?
I am using the Chevrolet Truck Shop Manual 1948-1951 Thx somerust
Jim D.
1953 chev 3800
bicycles 'n junk
mental fog
Hi again. Shown as 2 on the image attached. Simply grip it with needle-nosed pliers and pull upwards. It should slip right out. The spring is connected to it.
~ Jon
It is held in place by the flat area between 7 and 8 on the image below as well as the air horn to float bowl gasket.
~ Jon
Jon,
Yes, that did it! thank you for the help
Jim D.
1953 chev 3800
bicycles 'n junk
mental fog
