Topics128,162
Posts1,056,945
Members48,458
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Hello, New guy here, where would I post a carburetor question? 1953 model B carb on a 216, thank you, somerust
Jim D. 1953 chev 3800 bicycles 'n junk mental fog
somerust,
I have moved your post to the
Engine Shop for more conversation and help on the topic.
Dan
~ Dan
1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver)
Moderator, Electrical Bay
Hi and welcome to the site! What is your question?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
ok thanks for redirecting my post. I am learning how to use this cool site; computer use difficult to understand. unable to send a pic. Rebuilding a model B carb that is on a 1953 3800 216. How do I rotate the pump discharge guide, so I can remove it, the spring, and the ball? I am using the Chevrolet Truck Shop Manual 1948-1951 Thx somerust
Hi again. Shown as 2 on the image attached. Simply grip it with needle-nosed pliers and pull upwards. It should slip right out. The spring is connected to it.
It is held in place by the flat area between 7 and 8 on the image below as well as the air horn to float bowl gasket.
Jon, Yes, that did it! thank you for the help
