3 members (baldeagle, Jon G, Peggy M), 241 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#1510363 07/24/2023 6:27 PM
Im getting pretty partial to this 261. But this 3spd just aint cuttin the mustard.
What would i require to throw a T5 in this 51' 3100?
(Im upgrading to ifs and discs aswell.)
I did some searchin on hear and seen talk of putting one on a 235, but i dont know if it shares bellhousing with 261, and dont want to assume so.
"Commonly quoted life advice I dont even try to live by." -Famous Person
Should be the exact same process as a 235. Same bellhousing.
1951 3100
Ok thanks. I have a 94 s10 in the weeds. 2.2L 5spd. Im thinkin that should work. Then just have to figure out driveshaft to rearend.
I had a 287 AMC in a 63 Rambler Classic- - - - -outran everything, including the Nashville cops! No, I wasn't driving- - - -my cousin had borrowed it that night. The Ambassador 327 I put into a 64 Classic 9 passenger station wagon was even faster- - - -made it from Nashville to Little Rock AFB in 4 hours one night!
I have a pretty good idea how long the Nashville to Little Rock drive should take. That must have been quite a ride.
1951 3100
You’ll need an adapter to match bellhousing pattern. Earlier s10 t5s have the right bolt pattern. There are some input shaft considerations and couple ways to skin the cat.
A 94 would also have electronic speedometer, so you would lose that function without some further mods.
Go find Lugnutz’s profile and view his webpage on T5 swaps.
1951 3100
Check out this current '94 and later T-5 adapter plate discussion by member Lugnutz. It even includes info on what he did for drivehshaft on his vehicle.
I do think there may be more to this story though as you haven't mentioned if your 3 speed is still part of a torque tube rear end set up, or if your truck has been previously converted to an open driveline???
Dan
~ Dan
1951 Chevy 3 window 3100
Dan
Sorry good point. All stock. Still torque tube.
