1 members (1 invisible), 83 guests, and 3 robots.
Topics128,032
Posts1,055,519
Members48,425
#1510117 07/22/2023 4:32 PM
What type of brake fluid is a good choice in the 54 3100. Was going to try and move the truck today just to check things and no brakes.. checked and no fluid in it.. sooo what to use.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1510119 07/22/2023 5:00 PM
Regular Dot-3 fluid should be fine.
1949 gmc 1-ton
T-Doug #1510121 07/22/2023 5:07 PM
Thanks Johnny. Now to try and remember how to bleed them.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1510204 07/23/2023 3:45 PM
You might want to look for the leak...brake fluid doesn't just evaporate into thin air.
Bleed the system from the farthest wheel cylinder away from the master cylinder to the nearest.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
T-Doug #1510205 07/23/2023 3:58 PM
Have brakes now and will look for a leak.
Someone in the not to distant past redid the brakes. New master cylinder, brake lines, wheel cylinders, shoes and drums.
1954 Chevy 3100
Montgomery, AL
In Project Journals
