5 members (Stovebolt48, Tim Canfield, Hotrod Lincoln, jmoore, 1 invisible), 114 guests, and 3 robots.
Topics128,196
Posts1,057,385
Members48,469
#15099 04/04/2003 2:39 AM
Junior Member
Junior Member
does anyone know where to find front motor mount bolts, washers and bushings. Doesn't seem like anyone has those as aftermarket. Thanks again guys!
rebuild not replace
#15100 04/04/2003 3:18 AM
And the parts you are looking for would be for which year/model truck :confused: grin
#15101 04/04/2003 4:12 AM
Bob - if the mounts are for yer task force, about all yu'll find is the rubber donuts , which should be available at NAPA [useta be] - if ya need the pins and big honkin washers check the swap meet - also other than the brackets, the V8 mount is the same as the 6.
#15102 04/04/2003 3:32 PM
Junior Member
Junior Member
sorry, yes it is for a '59 Chevy.
rebuild not replace
#15103 04/04/2003 3:45 PM
Bob: If the v8 and 6 are the same "Brothers" has them in their new catalog page 120 pricey I think at $129.95 a set. popcorn
The Truth is Out There (I'll check a couple more mags)
