0 members (),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15099 04/04/2003 2:39 AM | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | does anyone know where to find front motor mount bolts, washers and bushings. Doesn't seem like anyone has those as aftermarket. Thanks again guys!
rebuild not replace
#15100 04/04/2003 3:18 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | And the parts you are looking for would be for which year/model truck :confused:
#15101 04/04/2003 4:12 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Bob - if the mounts are for yer task force, about all yu'll find is the rubber donuts , which should be available at NAPA [useta be] - if ya need the pins and big honkin washers check the swap meet - also other than the brackets, the V8 mount is the same as the 6. Bill | | |
#15102 04/04/2003 3:32 PM | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | sorry, yes it is for a '59 Chevy.
rebuild not replace
#15103 04/04/2003 3:45 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Bob: If the v8 and 6 are the same "Brothers" has them in their new catalog page 120 pricey I think at $129.95 a set. popcorn The Truth is Out There (I'll check a couple more mags) | | |
