1 members (DoubleB), 53 guests, and 0 robots.
Topics128,090
Posts1,056,024
Members48,432
Is it ok to jack up the rear end by placing the floor jack under the differential ? Its the way I've done it for decades on trucks, jeeps and SUV's.
Read an article this morning , unrelated to AD trucks, cautioned against using this method. Article suggested jacking under axle tube on each side seperately placing jack stand under the one side then move to the other.
What say the experts?
Ron - - Dusty53
1954 Chevy 3604
E Online: Content
What reasoning did the article give?
I've always jacked my vehicles that way and never had a problem. And I'm old and been doing it for a lot of years.
Brian
1955.2 3100 Truck
I've been doing it both ways since high school. No problems ever.
1950 Chevrolet 3100 (Ol' Roy)
The only reason I can think of not to do it from the pumpkin is that if you aren't on a level surface, the car will fall off the jack or the will jack tip over, etc.
Article ( again not for AD Trucks ) reasoned damage to the rear axle housing/tubes. Seems to me to be one of the strongest points in the driveline? I was curious as to what others thought on this, so I asked the question. I think I'll keep on doing what I have for the last 52 years since I owned my first car with a solid rear axle ( 55 Chevy two door Belair Hardtop ) and's that's to lift it from the pumpkin , place the jackstands and let it down.
Thanks to everyone for the input.
Ron - - Dusty53
1954 Chevy 3604
7
7 Offline
I wouldn't jack a heavily loaded truck from the center section, if it's empty then I don't see an issue with it. Theoretically you could bend the axle tubes at the center section if you were lifting from the center. Jacking from the axle under or as close to the spring perch would be preferred.
1 Offline
If I'm loaded my floor jack simply won't pick up that much on the rear, aside from the potential damage issue. Then, I use a 12 ton bottle jack under each spring saddle. The axle housings are pretty stout but there are limits. Empty I'll jack under the diff though.
1951 3800 1-ton
In the DITY Gallery
