0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#1509867 07/20/2023 12:19 PM
For the rearenders on the forum how difficult is the rebuild and setup on these 1/2 ton dropouts and is going to require any special tools other then the usual dial indicator and hand tools.
Are you talking about just swapping one third member out for an identical one?
1951 3100
No install new ring/pinion and all new bearings.
Go the Tech Tips part of the this site. There’s a pretty complete write up on installing the 3.55 R&P in an early rear end. Most of it would be totally applicable, just not the parts regarding the torque tube disassembly/ reassembly.
1951 3100
1 Offline
You might pickup a tube of HIghSpot blue or red lead to check the gear pattern when you think you're all done.
1951 3800 1-ton
In the DITY Gallery
