2 members (SammyC60, klhansen),
135
Mod | | | Forums66 Topics128,101 Posts1,056,518 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2023 Posts: 4 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 4 | I had my sm420 transmission brake band relined. The lining is too thick measuring 1/4 inch. What thickness lining should it have? So I can send it back and tell the reliner. Thanks, Jim
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | How tight is it...1/4" sounds about right...did you give the brake shop the drum diameter? Maybe they pulled the band to small/tight when the set the lining??? What year and size truck are you working on? Did you band get bonded or riveted? Post a picture or two... Mike B  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That sounds like it may be a little thick but I haven't worked on one in many years. There are a lot of adjustments on those things. Have you backed out the adjustments?
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2023 Posts: 4 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 4 | When I install it on the fixed end and around the drum it won’t turn I haven’t even started to tighten up the adjustment side. I was told it was a trans out of a 1958 3/4 or 1 ton I’m replacing my 3 speed and installing Napco running gear from 55 gmc into my 57 3600 I’m reading that dodge used similar setup and the lining is 5/32 | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If your installing a divorced transfer case you don't want the parking brake on the transmission...it the transfer case gets bumped into neutral the truck will roll away. NAPCO transfer case has the band brake on the rear output shaft to prevent this issue or they used the rear wheel service brakes as the parking brake. Mike B  | | | | | Joined: Mar 2023 Posts: 4 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 4 | Hi Mike I have a timken t-32 transfer case 55 and earlier had this two stick version the chassis I took it out of had no provisions for emergency brakes on the rear end and it looks like the e cables in my truck interfere with the t-case so talking to a guy that had a 55 Napco he said his e brake was transmission mounted that’s why I am headed this way appreciate your input I am looking for pictures of t-case linkage I have the two sticks but don’t know how they mount I think there is a cross brace rod from frame rail to frame rail and these levers attach to it jim | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You may need to search the rock crawler vendors to see if they have something that will work on your T-32... Mike B  | | | | | Joined: Feb 2001 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 41 | Just as a heads up, my 58 one ton NAPCO came with parking brake on the service brakes. Because of the lift, I had in-line tube match the longer one using my ends. I know where this truck has been it’s whole life, so I know it wasn’t altered. So you could always go that way. | | |
